Gearing set up.
Posted: Wed Aug 09, 2017 12:41 pm
by idc23
Just getting the t.v 175 3 ready it has a Mugello 186,Scootopia 42mm ancillotti,Dellorto 26 phbh carb,i want the gearing so it pulls up hills,would a 16x46 be better than 14x47,it has the original tv box, not so bothered about top end speed,any thoughts appreciated.
Ian :D
Re: Gearing set up.
Posted: Wed Aug 09, 2017 4:55 pm
by garry inglis
Tv175 standard 46x15 is 4-82 and was always good with the 175 but 46-16 is 4-52 getting quite tall 47×15 is 4-92 witch might be better
Re: Gearing set up.
Posted: Wed Aug 09, 2017 4:57 pm
by garry inglis
Have a look at these set upsImage
Re: Gearing set up.
Posted: Thu Aug 10, 2017 7:21 am
by Chris in Margate
Why not leave it standard ? About the best gearing set up you can have for your needs.
Re: Gearing set up.
Posted: Sun Aug 13, 2017 6:12 pm
by idc23
I have a 15x47 ,or a 15x46 4.9 or 4.8 a 14x47 came out ,remember i want it to pull up hills ,what shall i use.
Thanks Ian
Re: Gearing set up.
Posted: Sun Aug 13, 2017 8:39 pm
by garry inglis
Got this off Cambridge lambretta siteImage
Re: Gearing set up.
Posted: Sun Aug 13, 2017 8:41 pm
by garry inglis
Go on there site scroll down on home page and on the right it has the Facebook forum for mugello click on that and read
Re: Gearing set up.
Posted: Sun Aug 13, 2017 8:49 pm
by idc23
Thanks for reply's difficult to make the correct choice, will have a look.
Cheers Ian
Re: Gearing set up.
Posted: Mon Aug 14, 2017 4:23 pm
by corrado
14 x 47 = 5.28 final drive.
15 x 47 = 4.92 final drive.
15 x 46 = 4.80 final drive.
I'd opt for keeping the 14 x 47, it should go up anything in top gear with that ratio.
You [everybody] should download and learn to use the Lambretta gearbox visualiser by Tony Cassidy, it's a great bit of kit and tells you far more than just a series of numbers that may or may not mean much too you. You can see how the gears overlap according to the revs and you can compare 2 different gearbox set ups side by side.
Download it free from here .... https://avantone.wordpress.com/
