20mm Dellorto on LIS 150!
Posted: Sat Aug 05, 2017 11:02 am
by Martin20
Morning Guys.
Having problems with my 18mm delly on my 150 Special, so want to swap it for a 20mm one I have in the garage. Anyone running one with a 20mm, and if so , what jetting/slide are you using? Scoot is all standard with standard exhaust.
Martin
Re: 20mm Dellorto on LIS 150!
Posted: Tue Aug 22, 2017 7:54 pm
by Grumpy225
Posted: Wed Aug 23, 2017 8:57 am
by Tractorman
My LI150S import from Italy had a 18mm on that was well worn so I put a 20mm on, I will check the jetting and let you know. My mate bought a Pacemaker new from the local dealer in 1966 and it came with a 20mm carb on. I am sure about this because I checked it over to find out why it was quicker than my standard LI150.
Posted: Wed Aug 23, 2017 9:17 am
by Martin20
Tractorman wrote: ↑Wed Aug 23, 2017 8:57 am My LI150S import from Italy had a 18mm on that was well worn so I put a 20mm on, I will check the jetting and let you know. My mate bought a Pacemaker new from the local dealer in 1966 and it came with a 20mm carb on. I am sure about this because I checked it over to find out why it was quicker than my standard LI150.
Thank you!
