Flywheel weights (Monza Breakdown)
Posted: Mon Jul 31, 2017 5:36 am
On the way back from the Leicester rally yesterday, gave the scoot the beans off a roundabout (9K in 2nd) and pop!, cruised to a stop, quick check and no spark, got the bike home, did all the usual checks and worked backwards....... end result a sheared keyway and a spun flywheel.
A scary few minutes as this is a new built ultimate spec Monza 240 (done 250 miles), on close inspection the angels must have been looking down as no crank damage, tiny screwdriver and a lot of patience and managed to get the sheared part out of the crank.
Some very small scratches which should lap out, so to my question, i was using the AF mid weight (1920gms) flywheel, is this the usual weight people are using on RB's and TS1's etc.., is this too heavy for the spec of the engine or have i just been unlucky.
Before i order a replacement, any comments or recommendations welcome.
Spec is Pro-porting Monza 240, 62x110 PP crank, BGM stator (i tried the AF lightweight whilst building but would not work with the BGM) 29BHP.
Cheers
Cheers
