malossi mhr tmx 35mm jetting
Posted: Sat Jul 29, 2017 2:31 am
by ssteam177
hi all,
I'm running a tmx 35mm on my ported mhr 210 with vforce reeds etc
my jetting is
pilot 20
needle 58 2nd clip from top
main 300
looking for comparisons
thanks in advance
Re: malossi mhr tmx 35mm jetting
Posted: Sat Jul 29, 2017 5:38 am
by drunkmunkey6969
What crank are you running and how does the scooter perform? Tried any plug chops to check mix?
Personally I think the settings look a little lean, I'd be inclined to try 22.5p 56needle and 320 main...and work from there.
Posted: Sat Jul 29, 2017 6:46 am
by ssteam177
thanks for the reply !
its running a mazz bell crank 60mm which has a locktighted big end with rz mk pipe,
it out performs my other malossi 210 ()which is very much the same setup but with a keihin pwk 28mm 21.98hp dyno"d)
I've only just finished building it and only done about 10kms on it,
it feels abit lean in the mid range hence the reason for asking as i couldn't find anything on the internet in english
