Nylon lined cables
Can you use ordinary inner cables with these or do they have to be a specific type of inner? is it just the outer that is lined?
- EddieStone
- registered user
- Main scooter: Lambretta Li 150
- Contact:
I have nylon lined cables. I had a clutch cable break a month ago, and when I pulled out the old inner to replace it, it pulled out the whole nylon inner as well.
So now it's no longer nylon lined.
- coaster
- registered user
- Contact:
That happened to me a few weeks ago when changing a frayed clutch cable. I slid a new inner into it and the clutch was as heavy as hell, almost un rideableEddieStone wrote:I have nylon lined cables. I had a clutch cable break a month ago, and when I pulled out the old inner to replace it, it pulled out the whole nylon inner as well.
Thanks all.
- Ilango
- registered user
- Main scooter: SIL Vijai Super
- Contact:
Hi,eadmr04 wrote:Can you use ordinary inner cables with these or do they have to be a specific type of inner? is it just the outer that is lined?
Though I am not able to come up with a reason why not use ordinary inner cables with nylon lined outer, here in India Spaco makes Nylon lined cables and the inner cables are available as a separate spare.
However Spaco has named it "Ropes", rather than cables.
-Ilango
I've always used a spray of this when fitting too. Also use it on my pushbikes.
http://www.putoline.com/en/catalogue/pr ... uard/1903/
mr oppinionated
- registered user
- Main scooter: GTS300ie
- Contact:
The nylon lined cables I used to get from Taffspeed, where thinner and more tightly wound. I assumed that only they would fit the outers, but never had to try as they never snapped on me.
Mike
Mike
