SIP Road 2 Exhaust Fitting Woes
Posted: Tue Jul 18, 2017 9:09 pm
by GFlint
Hi All,
OK, fitted the SIP Road 2 on a PX200 but just couldn't set it up properly. Long story short noticed blowing and muck from exhaust stub area.
The exhaust seems to go as far up the stub as possible and clamped up tight, on closer inspection with it off I noticed that the weld on the inside was not tidy which could prevent full butting up of the exhaust and also the welded clamp at the top left a hole (where it was blowing) where the split comes down from the top.
Original exhaust re-fitted, no problem
Am I missing something, should there be another collet that goes between the stub and top of the exhaust?
If not, I'm not happy with the finish.
What you guys think?
https://www.flickr.com/photos/143575383 ... res/10Pr6e
Thanks in advance
Gary
