5 speed Jumping.
Posted: Tue Jul 18, 2017 2:27 pm
Hi all,
I've a slight issue with my Cyclone 5 speed jumping out of gear in 5th. I have to hold the gear change in position or it'll jump out of gear into a false neutral. It was put together a while ago by a dealer and it's not had a lot of use after it stripped a tooth early on. Anyway it was replaced and rebuilt and I've just started using it again and I've noticed this problem. The cables seem fine and are not too tight and the selector arm is 5 or 6mm clear of the casing when in 5th. Any ideas please fellas? Thanks in advance Pete.
