Page 1 of 2
Gp flooding or fuel starving
Posted: Wed Jul 05, 2017 6:44 pm
by dazblakey
I have had this a couple of times, I'm running a jetex can't afford a new carb at the moment but twice now on the same bend going up hill, I get like it's starving of fuel or flooding, it dies starts and runs, but full throttle nothing everytime I've tuck the carb off the float looks fine easily moving, it wrecked the new plug doing this shorted it out I presume to much juice, any ideas anyone
Sent from my D6603 using Tapatalk
Re: Gp flooding or fuel starving
Posted: Thu Jul 06, 2017 3:38 pm
by dazblakey
66views and no one can help
Posted: Thu Jul 06, 2017 4:25 pm
by Daggs
Viewer 67;
I'll offer a theory. Are you using a fast-flow petrol tap? If not , do so.
Also, possibly the carb inlet valve, operated by the float is too small.
Posted: Thu Jul 06, 2017 5:58 pm
by joespeed
and run with the filler cap slack or removed
Posted: Thu Jul 06, 2017 6:31 pm
by garry inglis
drill a small hole in the bottom of rubber hose to filter it could be fuel sitting there and flowing back into carb
Re: RE: Re: Gp flooding or fuel starving
Posted: Thu Jul 06, 2017 8:05 pm
by dazblakey
garry inglis wrote:drill a small hole in the bottom of rubber hose to filter it could be fuel sitting there and flowing back into carb
No sure which pipe your on about gaz
Posted: Thu Jul 06, 2017 8:33 pm
by garry inglis
The air hose from the carb that connects to air filter with it being a jettex you connect a rubber hose and they can fill with excess FUEL and cause problems so you put a hole in for the excess to drip out
Posted: Thu Jul 06, 2017 8:34 pm
by garry inglis
Posted: Thu Jul 06, 2017 8:35 pm
by garry inglis
Do you get me
Posted: Thu Jul 06, 2017 9:38 pm
by Scooterdude
Ive recently suffered the same scinario going round right hand corners, turned out to be the float set at the wrong height. it was flooding btw....
