series 2 forks
li mick
i have just bought a 1960 chrome ring series 2 li 150 frame and forks,i have a tv headset top and bottom which i would like to use but when i tried it on it looked as if the fork tube was about 25mm too short.
does this mean that i have to get an li headset or can i extend the tube?
thanks mick.
li mick
or is it the forks are the wrong model?
Are you talking S2 or S3 TV headset?
HxPaul
As far as I know,the only difference between the s2 TV headset and the s2 Li headset is the switchgear.Make sure that the forks are pushed right up at the bottom and the bearings are seated correctly.
hendy
Bottom bearing upside down?
li mick
ser 2 li150 frame,ser 2 tv headset i was just trying them together so i had not even put the bearings in yet,but it seems as though the forks are not long enough,as i have just bought the forks with the frame i was wondering if i had been given the wrong forks? and they may be off a GP.
hendy
Or Spanish s3 are about 3mm too short.
I just saw 25mm! They'd have to be gp then. But I didn't think even they were that much different.
hendy
Gp forks are 29mm shorter
joespeed
and have clip in rubbers ,no holes!
li mick
just had another look,they have holes for the rubbers.so not gp.
i'm going out to have another look again :)
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
