Page 1 of 2
series 2 forks
Posted: Wed Jun 28, 2017 10:51 pm
by li mick
i have just bought a 1960 chrome ring series 2 li 150 frame and forks,i have a tv headset top and bottom which i would like to use but when i tried it on it looked as if the fork tube was about 25mm too short.
does this mean that i have to get an li headset or can i extend the tube?
thanks mick.
Re: series 2 forks
Posted: Wed Jun 28, 2017 11:19 pm
by li mick
or is it the forks are the wrong model?
Re: series 2 forks
Posted: Thu Jun 29, 2017 1:04 am
by rosscla
Are you talking S2 or S3 TV headset?
Re: series 2 forks
Posted: Thu Jun 29, 2017 8:42 am
by HxPaul
As far as I know,the only difference between the s2 TV headset and the s2 Li headset is the switchgear.Make sure that the forks are pushed right up at the bottom and the bearings are seated correctly.
Re: series 2 forks
Posted: Thu Jun 29, 2017 1:42 pm
by hendy
Bottom bearing upside down?
Re: series 2 forks
Posted: Thu Jun 29, 2017 4:20 pm
by li mick
ser 2 li150 frame,ser 2 tv headset i was just trying them together so i had not even put the bearings in yet,but it seems as though the forks are not long enough,as i have just bought the forks with the frame i was wondering if i had been given the wrong forks? and they may be off a GP.
Re: series 2 forks
Posted: Thu Jun 29, 2017 10:56 pm
by hendy
Or Spanish s3 are about 3mm too short.
I just saw 25mm! They'd have to be gp then. But I didn't think even they were that much different.
Re: series 2 forks
Posted: Fri Jun 30, 2017 5:37 am
by hendy
Gp forks are 29mm shorter
Re: series 2 forks
Posted: Fri Jun 30, 2017 8:01 am
by joespeed
and have clip in rubbers ,no holes!
Re: series 2 forks
Posted: Fri Jun 30, 2017 8:38 pm
by li mick
just had another look,they have holes for the rubbers.so not gp.
i'm going out to have another look again
