Page 1 of 2
Recommend 175 kit
Posted: Mon Jun 26, 2017 8:49 pm
by dazblakey
Got a melted piston on my gp150 so decided to put a kit on it, don't want to change the crank so anyone got any recommendations please I haven't got a massive budget at the moment either
Sent from my D6603 using Tapatalk
Re: Recommend 175 kit
Posted: Mon Jun 26, 2017 9:09 pm
by Scooterdude
If your on a limited budget why not look at the Gori 200 kit? Seems decent and comes with a quality piston.
Posted: Mon Jun 26, 2017 10:34 pm
by hendy
Or a rebore, Mahle piston, cylinder head plus a tune?
Right side of £300.
Not saying it's a better option, just an option.
Posted: Tue Jun 27, 2017 8:45 am
by Tractorman
If you decide on a re-bore get it done somewhere that knows what there doing. I had one done at a local motorcycle dealer and it was a nightmare they some how managed to get the bore right at the top and bottom but narrower in the middle
I took it to Chiselspeed and they sorted out.
Posted: Tue Jun 27, 2017 9:24 am
by bristolmod
hendy wrote:Or a rebore, Mahle piston, cylinder head plus a tune?
Right side of £300.
+1. should come in well under £300.
Off the top of my head and using Scooter Restorations- Piston say £40; Head say £30; Rebore say £40; gaskets £5. Up the main jet a tad (assume you're using the standard 22mm carb?)
bore cylinder to 3.5 thou in old money.
Nice load of hot/cold cycles for running in and away you go.
Posted: Tue Jun 27, 2017 9:31 am
by bristolmod
P.S. Make sure the piston is the 175 CONVERSION PISTON, not an ordinary TV175 piston.
Posted: Tue Jun 27, 2017 9:45 am
by HxPaul
If you decide to put a kit on it,you cant do a lot better than fit a Casa 185.No need to change the crank although I've got one fitted on my series 2 with a Mec crank.
https://www.riminilambrettacentre.com/e ... t-185.html
Posted: Tue Jun 27, 2017 10:15 am
by hendy
bristolmod wrote:hendy wrote:Or a rebore, Mahle piston, cylinder head plus a tune?
Right side of £300.
Yes, WELL under £300. £150 quid for a very good tune.
Re: RE: Re: Recommend 175 kit
Posted: Tue Jun 27, 2017 9:44 pm
by dazblakey
Right side of £300.
Cheers Chris sounds like a plan
Posted: Tue Jun 27, 2017 10:49 pm
by Ryskie
dazblakey wrote:bristolmod wrote:hendy wrote:Or a rebore, Mahle piston, cylinder head plus a tune?
Right side of £300.
PJ Engineering in Wednesfield could sort the re-bore and probably sort a piston as well for you mate.
