Fibre Spacer on LT Coil
Posted: Fri Jun 23, 2017 11:28 pm
Hello
Just been rebuilding a stator after lowering the pickup height and managed to bust the fibre spacer that sits between the LT coil and the outer metal spacer that the laminates clamp up to.
Does anyone know what the purpose of this part is please? The outer metal spacer on this stator is a brass or copper 'L' shaped one and I've used an aluminium outer spacer in place of the broken fibre one. Just curious if this is a big no-no.
With the original set-up I'm not sure where heat is being transferred from and to where, either intentionally by design or unintentionally.
cheers
cheers
