AF Long Range Tank Test
Posted: Fri Jun 23, 2017 4:47 pm
by soulsurfer
Apparently AF send instructions on how to leak test their tank prior to fitting, does anyone have a copy they could share on here?
Thanks
Re: AF Long Range Tank Test
Posted: Fri Jun 23, 2017 6:42 pm
by a.lo.v2
strange they don,t do this prior to supplying them.
Posted: Fri Jun 23, 2017 10:09 pm
by Timbo
Fill up with water and look for leaks..... :roll: ........ :D
Posted: Sat Jun 24, 2017 12:19 pm
by soulsurfer
a.lo.v2 wrote:strange they don,t do this prior to supplying them.
Indeed :?
Timbo wrote:Fill up with water and look for leaks..... :roll: ........ :D
Im not sure thats a good idea... I read it somewhere, but I didn't read why :roll:
Posted: Sat Jun 24, 2017 1:14 pm
by fluff34567
Best way is to put the cap on and block the breather. Use a schraeder valve and plug into the tap connection. Give it some pumps until pressure is felt then hold underwater.
Posted: Sat Jun 24, 2017 1:18 pm
by YAMLAM
so, if you buy one , test it and it leaks ,do they refund your return costs ? or joe bloggs labour hours for making it fit for purpose ??
Posted: Sat Jun 24, 2017 9:34 pm
by davet
AF refund return postage costs???. I sent a faulty piston back and asked them to put 4 piston circlips in the replacement box. The scumbags still charged me a fiver to send it back to me.
Re: RE: Re: AF Long Range Tank Test
Posted: Sun Jun 25, 2017 5:28 am
by fluff34567
davet wrote:AF refund return postage costs???. I sent a faulty piston back and asked them to put 4 piston circlips in the replacement box. The scumbags still charged me a fiver to send it back to me.
Had similar with another dealer that totally cocked up an order , incorrect parts and missing parts etc . I want to order an additional gear selector trunnion thingy as they would send another.packet anyway, they wanted charge £8 for post!
