Petrol in gear oil, what symptoms would this cause
Posted: Fri Jun 23, 2017 12:56 pm
I had a look at a friend's 1960s vespa GL, it has a LML 150 5 port motor in it. First time I've seen it and it's not been run in 2 years. I go to drain the oil and to my surprise 700ml comes out very quickly. It does smell different than fresh oil.
My immediate thought is blown clutch side seal. But I don't know what oil was put in the first place or how much. Before telling the rider to go to the expense of an engine rebuild, I was thinking of suggesting the use it for a week or two and I'd drain the oil and see how much comes out (I put 300ml in).
From a practical stand point, what would be the symptoms you would notice to operation of fuel in the gear box? It may have been like this for awhile.
On a side note, a local rat b@5t@rd shop owner imported a bunch of LML engines he sold as new from the factory. After a rash of failures we figured out they were made up of bad aftermarket Indian parts. This may be one of those engines. But the rider is a single mom who loves her scooter but money is tight, so I want to be sure before I tell her it needs engine work.
Tx
David
Sent from my SM-G928W8 using Tapatalk
Tx
David
