Monza 225 phbh 30 and tsr evo exhaust
Posted: Sat Jun 17, 2017 3:27 pm
by Bensmith225
Running a monza 225 phbh 30 and a tsr evo exhaust, pulls clean but the cht seems high to me (between 130-145'C). I'm running 50 slide 55 idle av266 atomiser x2 needle (second clip down) and a 142 main. Does this sound about right. Tried different atomisers and clip positions and they're all too rich so this setup seems to work. Is it worth upping the main to bring the temperature down
Sent from my iPad using Tapatalk
Re: Monza 225 phbh 30 and tsr evo exhaust
Posted: Sat Jun 17, 2017 4:11 pm
by bazza3004
Have you tried a 40 slide. I ran a TS 230 (yeh i know that aint a monza) on the x13 av266 with no issues temp wise. Hope this helps.
Posted: Sat Jun 17, 2017 4:56 pm
by Bensmith225
Yeah I have, I could never get it to run right with a 40 slide
Posted: Sat Jun 17, 2017 5:41 pm
by Boreham
Hi Ben, the recommended slide for the Monza is much leaner, 50 slide
Posted: Sun Jun 18, 2017 9:21 am
by soulsurfer
Bensmith225 wrote:Running a monza 225 phbh 30 and a tsr evo exhaust, pulls clean but the cht seems high to me (between 130-145'C). I'm running 50 slide 55 idle av266 atomiser x2 needle (second clip down) and a 142 main. Does this sound about right. Tried different atomisers and clip positions and they're all too rich so this setup seems to work. Is it worth upping the main to bring the temperature down
Depends on what throttle position it's getting hot, have you considered an adjustable power jet?
Posted: Sun Jun 18, 2017 5:17 pm
by Bensmith225
It's between half and full throttle, I don't like running power jets
