GP200 CENTER STAND REMOVAL/ REFITTING.
Posted: Tue Jun 13, 2017 4:49 pm
by mickfeath.
Hi, could anyone help please and explain step by step procedure. I have looked at the "J " brackets and the splash plate, which are held onto the cross-member with 2 HEX bolts and nuts. One side is easily accessable using a socket, but the exhaust side is not. Is there a way to get at it, without removing floor boards etc. I have never done this before, so could you please forgive my ignorance and explain the procedure in simple terms.
Re: GP200 CENTER STAND REMOVAL/ REFITTING.
Posted: Tue Jun 13, 2017 5:02 pm
by Knowledge
If you remove the rear shock, the exhaust should swing out of the way sufficiently to allow you to use a socket on the end of the nut.
Having said that, the whole job is easier if you do remove the rear footboards, allowing the use of a open ended spanner in the channel of the cross-member.
Why are you removing the stand?
Posted: Tue Jun 13, 2017 5:14 pm
by mickfeath.
Hi Martin, the stand or the brackets seem bent, the scooter is really difficult to get off the stand, it seems to be sitting really low.
Posted: Tue Jun 13, 2017 5:17 pm
by mickfeath.
Iam thinking of letting a garage do it, how much "roughly" , do you think it would cost Maybe they could straighten the existing stand.
Posted: Tue Jun 13, 2017 7:45 pm
by cgt75b
Hi mate
Call round and see Geoff at Zootscoot to take a look at it, Cracking bloke very helpful.
Good luck.
Posted: Wed Jun 14, 2017 2:54 pm
by mickfeath.
Thanks for all your advice.
Posted: Wed Jun 14, 2017 3:54 pm
by bazza3004
It could be that the two bits that stick up on the top of your stand (the bits that butt up against your frame strutt) are bent. Iirc these should be inline with the stand legs.
Posted: Wed Jun 14, 2017 4:20 pm
by Timbo
Stand and fittings are relatively cheap to replace and fit yourself, so worth doing as a way of learning. The spring is a bugger mind but just down to practice...
