GP200 CENTER STAND REMOVAL/ REFITTING.
mickfeath.
Main scooter: lambretta super vijay 150
Hi, could anyone help please and explain step by step procedure. I have looked at the "J " brackets and the splash plate, which are held onto the cross-member with 2 HEX bolts and nuts. One side is easily accessable using a socket, but the exhaust side is not. Is there a way to get at it, without removing floor boards etc. I have never done this before, so could you please forgive my ignorance and explain the procedure in simple terms.
Knowledge
If you remove the rear shock, the exhaust should swing out of the way sufficiently to allow you to use a socket on the end of the nut.
Having said that, the whole job is easier if you do remove the rear footboards, allowing the use of a open ended spanner in the channel of the cross-member.
Why are you removing the stand?
Martin
mickfeath.
Hi Martin, the stand or the brackets seem bent, the scooter is really difficult to get off the stand, it seems to be sitting really low.
mickfeath.
Iam thinking of letting a garage do it, how much "roughly" , do you think it would cost Maybe they could straighten the existing stand.
cgt75b
Hi mate
Call round and see Geoff at Zootscoot to take a look at it, Cracking bloke very helpful.
Good luck.
mickfeath.
Thanks for all your advice.
bazza3004
It could be that the two bits that stick up on the top of your stand (the bits that butt up against your frame strutt) are bent. Iirc these should be inline with the stand legs.
Timbo
Stand and fittings are relatively cheap to replace and fit yourself, so worth doing as a way of learning. The spring is a bugger mind but just down to practice...
    Users browsing this forum: Amazon [Bot] and 6 guests
