Page 1 of 3
Lambretta crank
Posted: Tue May 30, 2017 10:38 am
by woody
Hi, I,ve blown my engine up and sheared the sx crank so I,m looking to upgrade to a gp crank. I,m looking to replace it with a mec-euro item , is this I a good crank ? and also they sell them in two sizes , which one is suitable for my engine , all standard internal set up with ally barrel 225 kit 30mm delly and sterling exhaust , cheers
Re: Lambretta crank
Posted: Tue May 30, 2017 11:27 am
by HxPaul
In answer to your question,yes they are a good replacement crankshaft.The standard size is 58x107.
Re: Lambretta crank
Posted: Tue May 30, 2017 12:48 pm
by Daggs
Blimey Woody. With that kit, I'm surprised the SX crank lasted 5 minutes.
Re: Lambretta crank
Posted: Tue May 30, 2017 1:30 pm
by ForemanBob
woody wrote:Hi, I,ve blown my engine up and sheared the sx crank so I,m looking to upgrade to a gp crank. I,m looking to replace it with a mec-euro item , is this I a good crank ? and also they sell them in two sizes , which one is suitable for my engine , all standard internal set up with ally barrel 225 kit 30mm delly and sterling exhaust , cheers
Yeah decent enough for what you need... Glasgow Lambretta have got them cheap as chips... Youll also need to change the magside bearing etc, and your flywheel...
Re: Lambretta crank
Posted: Wed May 31, 2017 10:23 am
by dazblakey
Sorry to jump in on your post, I've got a sterling exhaust to put on my gp and a 26mm carb would this be OK on crank and piston
Sent from my D6603 using Tapatalk
Re: Lambretta crank
Posted: Wed May 31, 2017 11:03 am
by woody
Yes mate I believe it would as I use a similar set up on one of my other scoots
Re: Lambretta crank
Posted: Wed May 31, 2017 1:25 pm
by bazza3004
The mec crank would be fine and are good value. Got the 60/107 from glasgow lambretta a couple of years ago and used it in an imola with no issues
Re: Lambretta crank
Posted: Wed May 31, 2017 2:47 pm
by woody
Ordered the 58x107 crank today £100 posted to me . cheers peeps
Re: Lambretta crank
Posted: Thu Jun 01, 2017 1:05 pm
by Darrell Taylor
hope its not the weak 107 rod type ,, i have around 30 in a box here i refuse to use prob ok on a std motor though
Re: Lambretta crank
Posted: Thu Jun 01, 2017 2:11 pm
by woody
oh bloody ell , how would I know the difference ?
