Page 1 of 2
Mugello rings
Posted: Sat May 27, 2017 5:36 pm
by nellyboyo
Thinking my Mugello needs a new set of rings but I can see they vary in price tremendously....or are out of stock ...or are in Germany ......
Can anyone see a problem in fitting these ??
The dimensions are the same ???
http://www.ebay.co.uk/itm/YAMAHA-TZ-350 ... SwQPlV8aUG
Re: Mugello rings
Posted: Sun May 28, 2017 7:02 am
by nellyboyo
Anyone ??
Re: Mugello rings
Posted: Sun May 28, 2017 10:08 am
by HxPaul
https://www.riminilambrettacentre.com/e ... 185cc.html
Rimini sell these to fit a casa 185 kit,they might fit your piston.If you ring Dean at Rimini he'll tell you if they fit.MB usually stock them but they're out of stock,but in their add they say that these fit Mugello and Casa pistons.
https://www.lambrettaspares.com/spares/ ... g6400.html
Re: Mugello rings
Posted: Sun May 28, 2017 10:25 am
by Scooterdude
Another option would be contact Mitaka UK and see if they can help you, lots of imformation on their site about crown height, skirt length etc, you may find it possible to use something like a standard Suzuki TS 185 ER piston that way you get a superior piston to what your using now + the rings will always be easy to get when you want them.
Re: Mugello rings
Posted: Sun May 28, 2017 2:37 pm
by nellyboyo
Ok , cheers boys , I would have thought rings designed for nicasil cylinders would be fine but I stand to be corrected ..
Re: Mugello rings
Posted: Sun May 28, 2017 5:26 pm
by HxPaul
But Casa and Mugello are nicasil lined.
Re: Mugello rings
Posted: Mon May 29, 2017 6:48 am
by nellyboyo
Yep , so these Yamaha rings should be fine ?
Re: Mugello rings
Posted: Mon May 29, 2017 8:20 am
by Scooterdude
nellyboyo wrote:Yep , so these Yamaha rings should be fine ?
Yes if they match the dimensions of the ring grooves on your piston.
Re: Mugello rings
Posted: Mon May 29, 2017 8:58 am
by nellyboyo
64mm x 1mm ....should be fine I would have thought ?
Re: Mugello rings
Posted: Mon May 29, 2017 9:14 am
by Scooterdude
There's only one way to find out....
