Page 1 of 2
Px poor running
Posted: Tue May 23, 2017 9:38 pm
by ducksta
Hi guys just road testing a px motor but first 2nd and 3rd runs boggy won't go over 30 mph 4th only just better,
Spec. Px 125 with a Dr kit matched to casings( piston correct way round ), casing has a lml reed valve fitted t5 24/24g carb with a polini induction kit crank been alterd to suit, exhaust is a revolver.
New CDI new stator plate
Carb be3. 55/160 132 main starts first kick but just won't go any ideas
Re: Px poor running
Posted: Tue May 23, 2017 10:31 pm
by Juan
Get shot of Polini ik and use an E. Never known anyone having luck using those and in the same vein the G only seems to work properly with a T5
Re: Px poor running
Posted: Tue May 23, 2017 10:33 pm
by ducksta
Got a 24/24 e carb any idea on jets etc
Re: Px poor running
Posted: Tue May 23, 2017 10:38 pm
by Juan
Not off the top of my head but you don't sound miles off on the list. Probably start about 125 on the main and see where you are.
Re: Px poor running
Posted: Tue May 23, 2017 10:46 pm
by ducksta
So you think it must be carb?
Re: Px poor running
Posted: Tue May 23, 2017 10:55 pm
by Juan
I think the Polini induction kit and T5 carb are issues here,both give problems. Both together are more than likely compounding things further.
Re: Px poor running
Posted: Wed May 24, 2017 12:08 am
by paul d
I've no experience of the lml reed valve but my T5 172 runs perfect on a 120 main, 122 with sito plus and 125 or 128 with the scorpion. Maybe a smaller main jet might be worth a try.
Re: Px poor running
Posted: Wed May 24, 2017 12:47 am
by Norrie Bodge
Juan wrote:Get shot of Polini ik and use an E. Never known anyone having luck using those and in the same vein the G only seems to work properly with a T5
I run a 24/24g carb with drilled air filter on my malossi 220 & no problems
Duksta if you do one adjustment at a time you'll sort it m8,
I'd Try a BE1 atomiser in for starts & if still boggy go down to the std T5 BE4 which is a lot leaner.
One step at a time with jetting m8 ok
& Remember to check your plug at various throttle positions
The BE3 one fitted is way richer m8 & what size air corrector you using ?
See the chart in this thread will help ->
viewtopic.php?f=8&t=27378
Re: Px poor running
Posted: Wed May 24, 2017 7:02 am
by ducksta
Cheers guys will revert back to the 24/24e carb and take induction kit off, standard filter and see if it improves.
Re: Px poor running
Posted: Wed May 24, 2017 9:18 am
by Ginch
I've been told that the LML reed opening is a closer match to a 20/20 (in terms of area) than anything else... so as well as any jetting issues, there may be a bottleneck at the reed for a bigger carb and higher flow venturi.
