Page 1 of 2
Smallframe Crank
Posted: Wed May 17, 2017 10:40 pm
by storkfoot
A mate had a "dealer" build him a small frame engine. His instruction was to build it as standard top end but with a race crank and decent bearings as the long term plan was to fit a Polini kit.
Anyway, the engine never got fitted and the mate has now bought the Polini Kit. I think it's a 130 but I haven't opened the box yet.
I said I'd fit the top end for him, albeit that I have never worked on a smallframe engine before. Having taken the top end off, I have some doubts about how this engine was put together.
My question relates to this crank. I know it's hard to tell without me splitting the casing, but does this crank look like a suitable race crank?
Re: Smallframe Crank
Posted: Thu May 18, 2017 7:18 am
by GeorgeS
Is this going to be using the rotary intake or reed on the barrell? Assuming rotary as it's not a full circle crank.
Can you post a picture of the crank intake cutout & perhaps measure the open timing?
You'd get best results by matching the casing transfers to the barrel & openning up the intake, but that would mean a casing split as you'd not want the waste ally getting in the crank.
Posted: Thu May 18, 2017 11:31 am
by storkfoot
I'll have to open up the parcel he has given me but I suspect it may be reed valve. I'll get back to you. Cheers.
Posted: Thu May 18, 2017 9:19 pm
by 225worb
Looks very much like a standard type crank or yes maybe a cut crank but if it were a reed type there would be signs of chamfering on the on all of the right side web and the inlet port wouldve been properly fettled !!!!
Posted: Sun Jul 09, 2017 12:38 pm
by storkfoot
Only just getting back to this. Stripping engine down to get at the crank.
My question is about the clutch. A large frame clutch will just prise out once you have taken the nut off under the thrust plate. I have done this but clutch doesn't seem to want to move. Should it prise off now?
Posted: Sun Jul 09, 2017 1:34 pm
by Boreham
The small frame clutch is on a taper, similar to the flywheel, requires the correct tool
Posted: Sun Jul 09, 2017 1:37 pm
by storkfoot
Thanks, mate. Just found reference to it in the Haynes manual, finally.
Posted: Sun Jul 09, 2017 1:42 pm
by Juan
Posted: Sun Jul 09, 2017 2:59 pm
by storkfoot
Thanks for those links. I'll re-register on the Smallframes forum too
Posted: Sat Aug 12, 2017 10:56 am
by storkfoot
