Piston Position in Barrel.
Posted: Tue May 16, 2017 8:37 pm
Evening All!
Newbie, novice mechanic here, so please bear with me if any of the following seems blatantly obvious!
A couple of weeks ago, due to a blown exhaust gasket, I dropped my LI 150 S engine, took off cylinder head and barrel. There was no base gasket under the barrel, just the remains of some sealant. When I built it all back up again, I used a base gasket, smeared in silicone (didn't measure thickness, but from memory, I would say with sealant, probably2.5 to 3mm). Lapped head and top of barrel, and added aluminium gasket. Tightened it all up, but as I did not have a suitable torque wrench at the time, didi it by feel! Yeah, I know, stupid! Anyhow, bike started, but within a few days, starting became more and more difficult, and noticing oil seeping between cylinder fins, guessed gasket was blowing. Stripped down again today and sure enough, oil on gasket and head.
I have now bought a suitable torque wrench, and new head gasket but reading loads of different posts on here re: gaskets,versus no gaskets,squish tolerances etc, I am looming for advice on the following:
1. The shoulder of my piston when at TDC is sitting approx 2mm below the top of the barrel. Is this OK, or should it sit flush with the top?
2. If piston needs to be at top, should I remove base gasket and just re fit using sealant?
3. Will not fitting a head gasket maintain the 2mm squish (is 2mm OK, or should it be less?)
4. Will highering/lowering barrel by fitting or not fitting a base gasket affect timing?
Hope above makes sense and sorry for length of post!
Martin
Martin
