Jockeys Boxenstop Final drive bearing
kejj
Hi all
Has anyone any experience from the final drive bearing developed by Jockeys?
http://www.jockeys-boxenstop.de/shop/en ... m_store=de
Looks like a smart idea.
________________________
http://tv175.wordpress.com/
DigDug
Yes I have one in my RB250 race engine. No issues so far.
Did you have to do that?
holty
Main scooter: lambretta gp
ive not seen the jockeys bearing but i have seen the new bearing being developed by rayspeed, its a sealed double bearing very much like whats fitted to front hubs on front wheel drive cars, they will be very strong.
holty
kejj
DigDug wrote:Yes I have one in my RB250 race engine. No issues so far.
So, was it a straight install? no removal of gear side plastic cage and such?
if, for any reason you'll need to replace the bearing, did it look removable from it's cage or the whole thing has to come out?
DigDug
You don't need to remove anything from the kit supplied.
Complete gearbox strip of course.
When required you just replace the bearing by removing the cir-clip in the carrier.
kejj
I installed it on my GT200 engine. Looked really good quality. The bearing is capsuled with oil seals and comes already greased. No need to remove seal. Just install. Top quality piece.
Skickat från min F3311 via Tapatalk
kejj
DigDug wrote:You don't need to remove anything from the kit supplied.
garry inglis
thanks for that kejj looks good
