P Range Headset Wiring?
Posted: Sat May 13, 2017 6:49 pm
by Lamaddict
I'm getting no power to the headlight and horn etc. Tnakfully, I''ve found another live on the ignition which was useful, so I've got one beam hooked up to that but which wire could I splice the new supply from to feed the other areas that need it?
Re: P Range Headset Wiring?
Posted: Sun May 14, 2017 8:47 pm
by ducksta
Check you have the correct switches for the loom, and check at regulator end that it's all correct.
Posted: Sun May 14, 2017 9:21 pm
by mick1
is it battery or none battery ? European spec' or USA ?
Posted: Mon May 15, 2017 2:14 am
by Lamaddict
mick1 wrote:is it battery or none battery ? European spec' or USA ?
Battery model. US spec but it's not a sealed beam. If I could just know the main wire colour going to everything normally I could just splice it onto the supply I've found on the ignition.
Posted: Sun Jul 16, 2017 5:33 am
by railfancwb
Here is a coded schematic I found. Hope it helps.
Posted: Sun Jul 16, 2017 8:56 pm
by ducksta
behind the horncasting the grey on the right hand side that loops 2 connections is the main power feed ive spliced this before for live feed
