Smallframe reed valve conversion
Posted: Wed May 10, 2017 8:22 pm
by Boreham
Converting casings to reed valve, the principal is simple however does anyone have optimum dimensions on the sealing pad side, widthwise is fairly obvious with removing the width of the pad to the casings and blend, the question is on the height, how deep do you go for optimum results.
Engine will be Polini EVO, Worb5 reed crank, mallossi reed intake.
Any images or dimensions appreciated
Re: Smallframe reed valve conversion
Posted: Thu May 11, 2017 1:49 pm
by holty
hello,
i built a polini 135 evo for my son a few years ago, it was a beast, i fitted the polini reedvalve manifold and it came with instrustions and measurements, if you look on the scooter help website under tuning-reedvalves there is a like to smallframes and it has a copy of the instrustions you can use,
holty
Posted: Thu May 18, 2017 9:27 pm
by 225worb
Smallframe forum will give you good advice and direction to go ,
A mate built a polini evo rotary with a 35 mm mikuni and mathias exhaust ......it was a right animal
There are a good number of small frame reed assemblies available take look on the S.I.P web site tooo for parts....
