carb choice for ts1 & comp ratio's
Posted: Wed May 03, 2017 6:46 pm
thinking of a new engine.
my mugelo 225 is 11 years old and now there is a left hand manifold available I don't need to chop off the battery tray and have a ts1 kit .
but which carb only want up to 30mm ish not as far as 35mm and want to run a filter
as I see it choices are
30mm phbh
30mm vhsh
30mm pwk genuine or has anyone tried the polini copy available from sip ?
27mm tmx
also what is considered a good comp ratio both geo & corrected for road / rally use
thanks Paul
30mm phbh
30mm vhsh
27mm tmx
thanks Paul
