rear hub play
lammy666
Main scooter: lambretta li 125/190 chop.
was out on my gp ts1 225 today and thought i had a rear puncture but on closer inspection its my rear hub.
i can move it from side to side to the point it feels as if it could come straight off.
hub nut is fully torqued up to correct setting.
any suggestions on what it could be.
bristolmod
wrong cone? Worn splines? Layshaft bearings?
You need to whip off the hub and investigate urgently.
Scootering since 1968.
bristolmod
end plate loose?
