Just bought an lami auto with a typhoon 125 engine kitted with a malossi 172. Thing wont move with a b9 plug in but fine with a b7, is this ok?
Is a 3% oil/fuel mix ok? Looks to me that this may be rich and a 2% mix may be better.
Thanks in advance.
Which Plug?
col68
- Main scooter: lambretta s2 li225 ts1
Both of my sons have had piaggio nrgs 50 cc water cooled and air cooled both ran perfectly well on a ngk 9 plug they both reved to 10000 plus on the road with arrow exhausts on running oil pumps I would think is 2% on rock oil race . same oil I run my ts1 lammy on . ngk b7 ok for around town but not in a revy motor 7 is is a hot plug 9 alot cooler hope this helps could try an 8 plug ran my vespa 166 malossi on one . col
Thanks col.
I had read that 9 would be right one, maybe I just bought a bad one. Always run an 8, on Ts1's and Malossi 210's, and been fine so tempted to try that on the basis it's a "middle of the road" option.
Always though 2% was a bit on the lean side but seems to be popular these days so may give it a go to.
