JB Weld ?
lockman69
M10 Exhaust Stud
Typical !...just built a new engine and the only stud I didn't have reason to check on the strip down as it didn't have a stud in it and this happened.
Can it be patched up with JB Weld or something similar ?
Minority
Main scooter: Li230 S3
Jb Weld is good.......but not that good ;)
ForemanBob
Main scooter: GP RT230
There is a product called Belzona that should be able to handle that.
http://www.belzona.com/en/products/1000/1111.aspx
lockman69
Sorry M8 stud not M10
holty
Main scooter: lambretta gp
it looks to me as though you will need it welding, you could try using something else like jb or belzona but i doubt that it will stay in place, the vibrations from the exhaust mounting will just shake it out, then you exhaust wil be hanging on one stud only, which isnt going to do that much good, it can be welded , try local engineering firms,
hope you get it sorted,
holty
Scooterdude
holty wrote:it looks to me as though you will need it welding, you could try using something else like jb or belzona but i doubt that it will stay in place, the vibrations from the exhaust mounting will just shake it out, then you exhaust wil be hanging on one stud only, which isnt going to do that much good, it can be welded , try local engineering firms,
holty
yes agree with this get it welded and re-tapped. Far to much damage to rely on a chemical "quick fix" good luck..
