Small frame clutch
Posted: Sun Apr 16, 2017 7:12 pm
by kevspeed
So people,what's the score with the cush drive?,there is a bit of play between the 'basket' and the drive wheel,is it worth re- doing the rivets so its solid again,or should I leave it as it is?
Its a bog standard Primavera,just replaced the seals and the clutch.
Re: Small frame clutch
Posted: Tue Apr 18, 2017 7:22 pm
by 225worb
Its wise to repair!!
if they let go , as in the retaining plate come away the spring(s) will drop out and lock up your engine !!!!! ive seen it happen!!! pulling the clutch will work to no avail !!
There are plenty of after market options which are pretty cheap, then there's higher end ones for tuned engines..
good luck
Posted: Fri Apr 21, 2017 7:12 pm
by kevspeed
Thanks fella,repair kit ordered 8-)
