float pivot pin stuck
Posted: Wed Apr 12, 2017 3:38 pm
by Suede Ed
Anyone got a tip to remove a pivot pin from a dellorto (standard SH) tried pulling with long nose pliers, no chance, do i have to destroy the float? Cheers.
Re: float pivot pin stuck
Posted: Wed Apr 12, 2017 4:05 pm
by Tractorman
Try warming the pillars with hot water and use vise grips instead of pliers.
Posted: Mon Apr 17, 2017 1:25 pm
by Adam_Winstone
I can't remember whether the pin hole / drilling goes all the way through on an SH or Jetex, however, on one or t'other I have managed to start it moving by poking the other end, then got it loose enough to remove from the correct end.
Good luck with it.
Adam
Posted: Thu Apr 20, 2017 10:02 am
by HxPaul
I've removed the pin using a vice,their was just enough of the pin to grip with the vice and pull it out.
Posted: Thu Apr 20, 2017 10:34 am
by Suede Ed
Cheers chaps, got it out using needle nose mole grips, following the carb being left in my new (off ebay) ultrasonic cleaner, ill put a post up on this later, including pictures.
