Tip for getting frozen engine case studs out.
Posted: Tue Apr 04, 2017 2:12 pm
Double nutting and heat was not working. But this did for 3/4
- heated case with yellow map gas
- inverted a can of air duster and blew on the stud near the base. The propellant comes out cold enough to freeze flesh. This made a massive thermal difference
- put penetrating oil on to let try and soak in
- double nutted the studs and tapped on the nut with a hammer to try and help break the corrosion bond
- used a stud removing tool. Kind that grabs the base and uses a 1/2 in ratchet.
- turned it in first, then out
3 out of the 4 came out. The last one snapped. So I drilled out starting with a small bit and jumping 1 size until I got close to the threads. Then tapped out starting at m6, m7, then m8 X 1,25 . Use new titanium bits and lots of oil. When tapping the motion in a bit forward then back off. Repeat.
A pain in the ass but if I wanted an easy life I'd drive a Honda.
DD.
DD.
