Page 1 of 2
Dog support
Posted: Sun Apr 02, 2017 12:48 pm
by dazblakey
Has anyone modified the dogleg support on the chain casing side so you haven't got to drop the engine out to take the casing off,on a gp
Re: Dog support
Posted: Sun Apr 02, 2017 1:38 pm
by gaz_powell
You don't have to - the side casing can be removed with it in place.
That's why the support is bolted and can be demounted
Re: Dog support
Posted: Sun Apr 02, 2017 1:47 pm
by dazblakey
I've tried I can't seem to get it past the studs to get it off so I've been dropping the engine out
Re: Dog support
Posted: Sun Apr 02, 2017 2:23 pm
by Scooterdude
That's the whole idea of having the two bolts..so you can take the leg off first so you can then remove the chain case.
Re: Dog support
Posted: Sun Apr 02, 2017 3:03 pm
by dazblakey
I take that bit of but still not enough clearance
Re: Dog support
Posted: Sun Apr 02, 2017 4:34 pm
by fluff34567
How are your panel gaps? The support frame bends quite easily, it might need a tweek.
Re: Dog support
Posted: Sun Apr 02, 2017 5:07 pm
by dazblakey
They all seem pretty good to be fair, was thinking of cutting it then putting a joining bracket in to make it dead easy
Re: Dog support
Posted: Sun Apr 02, 2017 5:22 pm
by dazblakey
Does the exhaust u bend have to be off
Re: Dog support
Posted: Sun Apr 02, 2017 5:29 pm
by bazza3004
Try removing the rear shock and either get someone to lift rear of frame or use a jack it should give you more clearence to get side case off.
Re: Dog support
Posted: Sun Apr 02, 2017 5:32 pm
by HxPaul
Unfasten the two bolts and nuts that hold it on to the support leg and remove it.Next place a thick peice of wood under the back of the frame,jack up without unfastening anything and the frame will be raised enough to remove the sidecover
https://www.google.co.uk/search?q=pictu ... pReIKtashM:
