Dog support
dazblakey
Has anyone modified the dogleg support on the chain casing side so you haven't got to drop the engine out to take the casing off,on a gp
gaz_powell
You don't have to - the side casing can be removed with it in place.
That's why the support is bolted and can be demounted
dazblakey
I've tried I can't seem to get it past the studs to get it off so I've been dropping the engine out
Scooterdude
That's the whole idea of having the two bolts..so you can take the leg off first so you can then remove the chain case.
dazblakey
I take that bit of but still not enough clearance
fluff34567
How are your panel gaps? The support frame bends quite easily, it might need a tweek.
dazblakey
They all seem pretty good to be fair, was thinking of cutting it then putting a joining bracket in to make it dead easy
dazblakey
Does the exhaust u bend have to be off
bazza3004
Try removing the rear shock and either get someone to lift rear of frame or use a jack it should give you more clearence to get side case off.
HxPaul
Unfasten the two bolts and nuts that hold it on to the support leg and remove it.Next place a thick peice of wood under the back of the frame,jack up without unfastening anything and the frame will be raised enough to remove the sidecover
https://www.google.co.uk/search?q=pictu ... pReIKtashM:
    Users browsing this forum: Semrush [Bot] and 9 guests
