Gear selector/ sliding dog wear
Posted: Tue Mar 28, 2017 9:27 pm
by fluff34567
Are there any set measurements /wear limits for the fingers of the gear selector? Mine is rounded...
Replace or is it OK? Will be in a non tuned engine
Re: Gear selector/ sliding dog wear
Posted: Wed Mar 29, 2017 7:07 am
by Scooterdude
It doesent seem to have to much wear unlike mine that started jumping out of gear so I'd use it if you have no gear jumping issues.
Posted: Wed Mar 29, 2017 4:18 pm
by fluff34567
Found a SIL one for £25 so for the time and hassle of changing it if it does jump in a year or 2 I don't mind the small cost
Posted: Wed Mar 29, 2017 5:06 pm
by holty
fluff34567 wrote:Found a SIL one for £25 so for the time and hassle of changing it if it does jump in a year or 2 I don't mind the small cost
a good plan, i would have changed it as well, you know it will last longer with a new one.
Posted: Wed Mar 29, 2017 8:19 pm
by storkfoot
Compare the smoothness of the track that the bearings run on with the original. I had a SIL one that had a rough track which made gear changes a nightmare.
Posted: Wed Mar 29, 2017 9:00 pm
by fluff34567
Will do
Posted: Wed Mar 29, 2017 9:40 pm
by Doom Patrol
SIL ones can be very crotchety. I'm using one. And while it has improved with wear I still can't get it into first gear without the engine rolling.
