Creeping backwards when revved
Posted: Mon Mar 27, 2017 12:12 pm
by Blenks
Re: Creeping backwards when revved
Posted: Mon Mar 27, 2017 12:22 pm
by Toddy
In Gear ? or just Vibrating on the stand ?
Posted: Mon Mar 27, 2017 3:40 pm
by Blenks
No not in gear, just in neutral ticking over. If I twist the throttle to rev the engine it moves backwards. It is not vibration as it does not move when ticking over and is a definite backward movement.
Posted: Mon Mar 27, 2017 3:47 pm
by gaz_powell
its just creep from vibration - often happens when your stand/struts aren't perfect and the bike isn't planted on the ground - check your stand feet aswell.
Posted: Mon Mar 27, 2017 3:54 pm
by Blenks
The stand feet on it are aluminium so I had a thought that it may be because they have no grip. Seems very reasonable. Thanks for the suggestions. Looks like a new pair of feet then. Cheers.
Posted: Mon Mar 27, 2017 4:25 pm
by garry inglis
rubber is best
