Jetting in 210
Posted: Sun Mar 26, 2017 1:33 pm
I'm trying to get my 210 running, NOS older kit.
Spec is -
Ported casings modded for reed
MRP flat reed
New Si24/24
60mm crank
SIP Head packer at the head as per SIP rec for 'torque' tune
SIP Touren lightened flywheel.
Couldn't get it to run at all well with the old carb so borrowed a standard one of my brothers PX and with no changes to jetting it started better and ran a bit better. So I got a new one and have fitted it.
Basic jetting when I got it was - stack 160/BE3/118, pilot 55/160
Initially I just put in a 132 main and set the mixture screw 1 1/2 turns out. It started on the choke and would tickover but a little high but wouldn't tickover off the choke. Adjusting the mixture out a 1/4 turn at a time I get to about 4 turns out before it would settle off the choke and even then it would die on opening the throttle.
I think this means it's not getting enough fuel as it comes of tickover, so I changed the pilot to 55/100. It now will rev of tickover but still seems a bit rough.
Am I going in the right direction?
Spec is -
MRP flat reed
New Si24/24
60mm crank
