Page 1 of 2
Spark Plugs
Posted: Sat Mar 25, 2017 10:58 pm
by Doom Patrol
I recently fitted a Denso spark plug and my engine felt a little constipated. I put it down to not being used so much in the winter. But today I couldn't get it to run. It would fire, but that's about it. Definitely a spark there. And correctly gapped. I tried an NGK B7 and it fired up straight away and runs nice and crisp. So why are some plugs good and others not?
Re: Spark Plugs
Posted: Sun Mar 26, 2017 8:07 am
by fluff34567
I suspect you had a rare duff denso as they are very good plugs.
Would be interesting how it performs in another scooter
Re: Spark Plugs
Posted: Sun Mar 26, 2017 10:04 am
by purple_pill67
Use denso myself and have had no issues
Re: Spark Plugs
Posted: Sun Mar 26, 2017 11:48 am
by Doom Patrol
Perhaps it is a bad one. I have used Denso before without issues. Curious that it seemed to spark fine. Maybe it was the wrong sort of spark, I don't know. I might try closing the gap a fraction and see if it makes it stronger.
And while we are on the subject who does a half decent plug spanner? If you manage to get them on you've got very little turn in it. You could almost do with some sort of ratchet.
Re: Spark Plugs
Posted: Sun Mar 26, 2017 12:17 pm
by garry inglis
Hi doom this is what I made for my ts230 and rb200 were getting in is tight use a plug socket out of your tool kit cut 10mm of the bottom take rubber insert out and fit on your plug in the scoot till you get a square edge Mark it with felt tip and weld an old spanner I used a 12mm as it fits my wheel nuts and basically as you drop it in you only have to move it and it's either tightens or undone
Re: Spark Plugs
Posted: Sun Mar 26, 2017 12:25 pm
by garry inglis
Re: Spark Plugs
Posted: Sun Mar 26, 2017 12:28 pm
by Doom Patrol
That's very ingenious. I suppose you could do something similar with your existing plug spanner and some sort of ratchet spanner if you cut it down and welded a nut on top?
Re: Spark Plugs
Posted: Sun Mar 26, 2017 3:11 pm
by HxPaul
I use the plug socket and ratchet out of one of these socket sets,works a treat.
http://www.ebay.co.uk/itm/40-PIECE-PC-D ... 4ae9c7897e
Re: Spark Plugs
Posted: Sun Mar 26, 2017 6:01 pm
by Timbo
Doesant get better than a MB one, easy to do by hand or use a ratchet
http://www.lambrettaspares.com/spares/t ... p0267.html
Re: Spark Plugs
Posted: Sun Mar 26, 2017 8:38 pm
by rosscla
^ +1
