vespa bearing and seal advice.
Posted: Tue Mar 21, 2017 9:46 pm
by lammy666
evening lads, can anybody give some advice on what bearings and seals i should fit to my 2012 px 125.
its just there are so many makes and types :shock: .
my set up will be bgm 177 top end, 26mm si carb 58mm maz crank and a jl pipe.
my current top end is/was a malossi 166 but my clutch side seal went on the way home from the southport vfm rally :(
Re: vespa bearing and seal advice.
Posted: Fri Mar 24, 2017 7:41 pm
by gaz_powell
Any reputable bearings SKF, NRB, NSK, SIP, etc will be fine - for seals in my experience I use only Corteco and Yamabond them in.
