Sip/AFR valve
Posted: Mon Mar 20, 2017 8:51 pm
Can you fit a SIP valve in an AFR tubeless alloy rim?
essexgp wrote:Its screw in on the AF rim but the SIp one seems to small
Thanks Martin, didnt want to pester you as youve been so helpful, wasnt to worried as I now need the SIP valve for the front wheelcorrado wrote:I had assumed that they were the same as led to believe they're made in the same factory and the pic on AF's website looks the same. If I can remember I'll look at some AF rims I've got and see if I can see any difference. Not too keen on unscrewing them as one snapped on me once.
Dont worry, ive had a look at thread with a magnifying glass and it seems the previous owner has wrecked the thread in the rimcorrado wrote:I had assumed that they were the same as led to believe they're made in the same factory and the pic on AF's website looks the same. If I can remember I'll look at some AF rims I've got and see if I can see any difference. Not too keen on unscrewing them as one snapped on me once.
Just fitted two of these valves to ScootRS tubeless rims,it may fit your rim http://www.ebay.co.uk/itm/191954297718? ... EBIDX%3AITessexgp wrote:Dont worry, ive had a look at thread with a magnifying glass and it seems the previous owner has wrecked the thread in the rimcorrado wrote:I had assumed that they were the same as led to believe they're made in the same factory and the pic on AF's website looks the same. If I can remember I'll look at some AF rims I've got and see if I can see any difference. Not too keen on unscrewing them as one snapped on me once.
So that one f****d rim with a hardly worn tyre thats going to have to come off![]()
