Page 1 of 2
cracked clubman
Posted: Wed Mar 15, 2017 7:21 pm
by hendy
just putting my bike back together after a big winter overhaul and noticed this. I'm sure it was fine when I took it off, but I guess I wasn't paying attention as it's only been run for 5 minutes since rebuild to set timing.
what's the best course of action? get it brazed? I suspect it will just crack again, but it'll be a canny bit cheaper than getting a new pipe (£200 plus they have none).
I would go for a gori race 50mm but they're £300!
Re: cracked clubman
Posted: Wed Mar 15, 2017 7:30 pm
by holty
i would weld that up, and put a patch over it so it wont split again, i guess it must have been a bit tight when fitted and the vibrations have split it, dont suppose your coming anywhere near hull so you could drop it off ?
holty
Re: cracked clubman
Posted: Wed Mar 15, 2017 7:42 pm
by fluff34567
If you weld make sure to stop drill the ends of the crack or it will.continue to crack
Re: cracked clubman
Posted: Wed Mar 15, 2017 7:50 pm
by hendy
holty wrote:i would weld that up, and put a patch over it so it wont split again, i guess it must have been a bit tight when fitted and the vibrations have split it, dont suppose your coming anywhere near hull so you could drop it off ?
holty
No, it's a bgm so their mounting arrangement make them stress-free. Otherwise I'd have concluded the same thing. I can't really understand how it happened.
I never get near hull these days but thanks anyway. It's due a dyno session as I've had the barrel and head modified plus a 60/110 crank. So I'll see if Mick Abbey will kill two birds with one stone. He's only a 30 mile ride from mine.
Re: cracked clubman
Posted: Wed Mar 15, 2017 10:37 pm
by Timbo
How old is the Clubman?
Re: cracked clubman
Posted: Wed Mar 15, 2017 10:53 pm
by hendy
I put it on not long before the breighton ferry rally last year, but I'd owned it since at least a year before that. It spent a long time under my bench.
I'd guess that it's covered around 1000 miles.
Re: cracked clubman
Posted: Wed Mar 15, 2017 11:35 pm
by Scooterdude
If you want to send it to me I'll repair it for you foc, I'm getting good at welding up clubman exhausts.
Re: cracked clubman
Posted: Thu Mar 16, 2017 4:20 am
by Muttley McLadd
There was an RS one on ebay the other day. Checked.. still is:
http://www.ebay.co.uk/itm/302223109135
Re: cracked clubman
Posted: Thu Mar 16, 2017 7:12 am
by hendy
Scooterdude wrote:If you want to send it to me I'll repair it for you foc, I'm getting good at welding up clubman exhausts.
What a smashing fella.
Pm sent
Re: cracked clubman
Posted: Thu Mar 16, 2017 7:50 am
by hendy
Muttley McLadd wrote:There was an RS one on ebay the other day. Checked.. still is:
Thanks, I did think about that but the engine is nice with the bgm and has a much larger downpipe so I think the rs may hold it back a little.
Plus there'll probably be a bidding war on that.
