Avanti cylinder head..
Posted: Tue Mar 14, 2017 11:22 am
by 225worb
I'm needing some advise on the quality, pros and cons of the avanti cylinder head on a TS1 to using the standard type.
Re: Avanti cylinder head..
Posted: Tue Mar 14, 2017 9:48 pm
by paulnobodyimportant
Larger head with more mass means that it will run cooler than standard head. Got one on mine, well nearly, it will be on by Friday afternoon . Going to Southport on Saturday so will see what the actual CHT says on SIP speedo. Cons are that you need a matching GRP cowl. Plus, may need extended studs as a mate of mine found. Anyway, AF Rayspeed have a similar head called the Mammoth.
Posted: Tue Mar 14, 2017 10:13 pm
by jonashford
The head cowl is fibreglass. I've never bothered to put the head stud nuts in just the msg flange bolts, it's been like that since it was fitted & since Ron bought them out
Posted: Tue Mar 14, 2017 11:15 pm
by 225worb
Great...
The Ts engine I've just acquired has one fitted...
