PM Tuning PX Front Brake Caliper
Posted: Sat Mar 11, 2017 9:36 am
by Blakey43
Has anyone had problems bleeding a PM tuning billet caliper on a PX disc set up. Tried everything, still can't get it even using an easy bleed. Put the standard caliper back on and it bleeds easy so I know it's the caliper. Can anyone help?
Re: PM Tuning PX Front Brake Caliper
Posted: Sat Mar 11, 2017 10:45 am
by jimmers
Bleed nipped blocked? Take it right out see if fluid comes through?
Posted: Sat Mar 11, 2017 1:06 pm
by coaster
I have an SIP billet caliper on my Zip front wheel conversion, I had to use a syringe (blagged from the chemists) to suck the fluid through.
Posted: Sat Mar 11, 2017 1:59 pm
by rosscla
I discarded the ball style nipple on the SIP caliper after spending hours and about 2 litres of brake fluid trying to bleed it.
Make sure your bleed nipple is actually sealing and worth trying to fill from the bottom up.
Posted: Sun Mar 12, 2017 8:44 pm
by Blakey43
Everything seems clear but I can't pull or push fluid through it. There's two small grub bolts on the caliper I can't see what they're for, I wonder if they have anything to do with it ?
Posted: Sun Mar 12, 2017 8:57 pm
by Blakey43
Posted: Sun Mar 12, 2017 9:00 pm
by Blakey43
Posted: Sat Jun 09, 2018 6:15 pm
by Hedges
Did you get sorted in the end?
Got same issues, had a bit of a brake for a year or two, thought I’d have another go but now I’ve no brake
Any tips with this pm calliper?
Posted: Fri Jun 29, 2018 11:10 pm
by Blakey43
Funnily enough I’ve just been trying again tonight with a different scooter. Same problem. I think it’s the bleed screw itself not sealing properly, slacken it off 1/4 of a turn pump the brake and I can see fluid coming out through the nipples thread
God knows I’ll see if I can get another nipple
