Page 1 of 2
lambretta clutch cush
Posted: Wed Mar 08, 2017 8:43 pm
by holty
ive been looking at a few various clutches from motorcycles to see if i could attactch one to a lambretta crownwheel , this is intended to go into my rotax 290 so must be able to handle high bhp and torque, my thinking is it might help give the gearbox a longer life,i was thinking i would have to extend the cover outwards with a packer to give enough room,has anyone had any success doing this in the past,
thanks in advance,
holty
Re: lambretta clutch cush
Posted: Wed Mar 08, 2017 9:02 pm
by Adam_Winstone
Is that not the same as the SI crownwheel?
Posted: Wed Mar 08, 2017 9:07 pm
by holty
youve lost me there adam, ?
Posted: Wed Mar 08, 2017 9:14 pm
by Adam_Winstone
Rear crownwheel with inbuilt cush drive, as per Series I...
https://lh3.googleusercontent.com/-oNsV ... 6%2Bth.JPG
another example...
https://www.picclickimg.com/d/l400/pict ... talian.jpg
Posted: Wed Mar 08, 2017 11:48 pm
by Knowledge
To be honest Holly, your original post is a bit short of info. It is only in the title that you mention a cush, but not in the thread itself. However, this is what Adam has picked up on.
What do you want? A motor cycle clutch with integral cush, installed in a Lambretta casing?
Posted: Thu Mar 09, 2017 9:37 am
by holty
hi , sorry i didnt explain myself very well, i want to make a cushdrive to fit into a lambretta crownwheel,that fits a lambretta engine casing it will need to be very strong as it is for my rotax 290 conversion,so i was thinking of adapting a motorcycle clutch that has an inbuilt cush, i will have to pack the side case out which i dont mind doing, i have a yamaha clutch with cush drive i thought about using but that clutch dissengages with a pushrod through the center so the pushrod would have to come from the inside which is no good, i will need the clutch to be pushed in from the outside as a lambretta clutch is, hope that makes it a bit clearer,
cheers,
holty
Posted: Thu Mar 09, 2017 10:21 am
by Adam_Winstone
^... yep, I get it but thought it interesting that you might be thinking back to the concept behind Innocenti's initial SIII (and earlier) clutch design. Indeed, did I read somewhere (Scootering's review of the original Innocenti twin motor?) that Innocenti had resorted to fitting a sprung rear sprocket to the twin as the front sprocket does not have the typical front sprocket transmission damper?
When it comes to fitting a motorcycle cush clutch to a Lambretta, best I sit back and watch (with interest) whilst you do it!
Posted: Thu Mar 09, 2017 10:38 am
by holty
i intend to keep the front damper as well, i just want to give the gearbox an easier life, if you can do that with a high output lambretta engine,
cheers adam
holty
Posted: Mon Mar 13, 2017 9:19 pm
by joespeed
hi mr holt,i do believe casa have done such a cush drive in their latest clutch for their high horse power case/kit,have a look on their website.does look nice which usually means expensive!
Posted: Tue Mar 14, 2017 7:40 pm
by holty
joespeed wrote:hi mr holt,i do believe casa have done such a cush drive in their latest clutch for their high horse power case/kit,have a look on their website.does look nice which usually means expensive!
hi joe,
yes i have seen those, i didnt even find out the price as i know they will be over my budget, i want something thats affordable and works without a massive price tag, im sure i can find a motorcycle clutch that i can make work, a visit to my local bike breakers is in order, thanks for the pointer. :D
