1st gear lacks power
Posted: Wed Mar 08, 2017 2:02 pm
Finally I have my GP back on the road and MOT'ed
Its been off the road for a while as I changed the engine. Replacing the std one with a new block fitted with a SR175. The MOT run was the first drive of substance that I'd under taken and what I noticed was that I was really having to quickly open the throttle quite far in first gear to get enough power to accelerate properly. It seems ok in other gears but I am still running in so was not trying to rag it anyway
I've checked that the throttle cable is adjusted properly so that its not me having to wind the throttle open before the slide moves.
Full spec
25 mm dellorto
pilot 45, starter 60 mail 122 (on the big side I know but should not affect it until I open the throttle fully)
Af Reverse cone clubman (sick of it already)
Gearing is Indian gp125 with stretched chain
Tuning I did myself but was nothing drastic.
Now it could just be me, my vega has a quick action throttle and the only other scoot I've really ridden in the last 10 years is this GP in std form but I dont remember it needing to be like this. maybe some scoots just need you to do this once you start messing around with them in terms of changing them from std? Thoughts please
Full spec
25 mm dellorto
