Page 1 of 2
Panel locks.
Posted: Thu Mar 02, 2017 9:57 pm
by 10 inch Terror
Hi all,
After recently losing a panel I'll going to fit some panel locks. The locks are the small type that you get on data cabinets etc. Has anyone got the dimensions and measurements of where best to fit them please? Thanks in advance Pete.
Re: Panel locks.
Posted: Thu Mar 02, 2017 10:55 pm
by gaz_powell
Fit them in line with the rear frame grille
Re: Panel locks.
Posted: Thu Mar 02, 2017 10:56 pm
by gaz_powell
Re: Panel locks.
Posted: Fri Mar 03, 2017 9:49 am
by Timbo
I have an SX with standard Spring clip (not rollers) and I simply put a very small jubilee clip on the end once the panel is on. Does the job and should stop the chancers/scum bags. I've not done anything about my GP clip on panels but thought a very small screw at the very bottom of the rear of the panel. Anyone got any ideas?
Re: Panel locks.
Posted: Fri Mar 03, 2017 11:35 am
by HxPaul
10 inch Terror wrote:Hi all,
http://www.ilambretta.co.uk/forum/viewt ... rity#p4660
Re: Panel locks.
Posted: Sat Mar 04, 2017 5:07 pm
by 10 inch Terror
Thanks chaps.
Re: Panel locks.
Posted: Sun Mar 05, 2017 5:11 pm
by gaz_powell
im sure you already know but if not you need 20mm deep - pair keyed alike
Re: Panel locks.
Posted: Sun Mar 05, 2017 6:07 pm
by 10 inch Terror
gaz_powell wrote:im sure you already know but if not you need 20mm deep - pair keyed alike
Yes mate. I've already fitted them. Thanks anyway.
Re: Panel locks.
Posted: Mon Mar 06, 2017 6:30 am
by 10 inch Terror
Just thought I'd add that the panel wasn't stolen, if came loose and fell off.
Re: RE: Re: Panel locks.
Posted: Mon Mar 06, 2017 8:27 am
by fluff34567
10 inch Terror wrote:gaz_powell wrote:im sure you already know but if not you need 20mm deep - pair keyed alike
Photo if possible?
