welding advice
Posted: Mon Feb 27, 2017 1:31 pm
i need to have the indicator holes welded up on a headset bottom. cannot just fill them because its off to get engraved then chromed. any advice on type of weld etc. Thanks
That will do for me thank you very much, I'm just outside Hull. Thanks holtyholty wrote:tony from ajs aqua blasting does repairs to lambretta headsets, ive just lent him a gp healamp ring so he can get the shape correct on a headset he is repairing, ive seen his repairs and they are of the highest standard, i do also have an engine casing with him that he is going to weld for me, he is down chamberlain road in hull, he also does aqua blasting which is the perfect finish to prepare for paint, a realy nice bloke as well.
glad to be of service, he is a top mechanic, but very busy, you might have to wait a short while, but you will get a top notch job, people send him parts from overseas to repair, just google aj s aqua blasting and you will find his numberchippy wrote:That will do for me thank you very much, I'm just outside Hull. Thanks holtyholty wrote:tony from ajs aqua blasting does repairs to lambretta headsets, ive just lent him a gp healamp ring so he can get the shape correct on a headset he is repairing, ive seen his repairs and they are of the highest standard, i do also have an engine casing with him that he is going to weld for me, he is down chamberlain road in hull, he also does aqua blasting which is the perfect finish to prepare for paint, a realy nice bloke as well.
