Malossi 166 long stroke
ducksta
Hi guys anybody run a malossi 166 kit with a 60mm crank if so what carb/exhaust set up and how does it run
ducksta
Anybody?
Is that not what Dan is doing with his dyno donkey articles?
ducksta
I need feedback on the malossi kit
ducksta
Any other takers
OzOAP
Main scooter: Vespa PTS1E
I run a Malossi 166 with a 200 60mm crank. So long stroke/long rod. Packplate under barrel, modify piston windows to line up with ports. 30mm phb carb, PM pipe.
19hp on PM dyno. Goes well. Engine was my rally hack for many years with PX125 gearbox/P2 primary, now in scootercrosser frame with T5 primary.
ducksta
ducksta
P2 primary is?
ducksta
Just finishing the build. Malossi 166 barrel tuned head opened up 60mm Mazz crank casings ported/matched drt reed valve 28mm dellorto with built in power jet and a sip road 2
    Users browsing this forum: Semrush [Bot] and 0 guests
