Page 1 of 3
Cone steering bearing upgrade.
Posted: Sat Feb 25, 2017 9:02 am
by 10 inch Terror
Hi all,
I remember seeing somewhere a nice steering upgrade for Lambrettas using cone bearings rather than the traditional type. I'm sure Taffspeed made them But I can't find any via a google search. Could anyone point me in the right direction please. Thanks in advance Pete.
Re: Cone steering bearing upgrade.
Posted: Sat Feb 25, 2017 9:58 am
by storkfoot
I think I have seen them on Facebook but I am sure, if you phone the Taffspeed number on their website, they'll be able to help you.
Posted: Sat Feb 25, 2017 10:50 am
by dansacred
eBay
Posted: Sat Feb 25, 2017 10:57 am
by Eibar
Terr frankland facebook
Posted: Sat Feb 25, 2017 11:17 am
by Donnie
seen them but dont get it
Posted: Sat Feb 25, 2017 3:09 pm
by fairspares
Donnie wrote:seen them but dont get it
Me either , most of the weight of the frame etc is on the lower bearing which is where an upgrade should be done.
Posted: Sat Feb 25, 2017 7:57 pm
by holty
the bottom bearing has much bigger balls so is stronger, plus you can always add lots of balls and no cage, top however is made with very small balls so isnt as strong, probably aimed at scooters with a good front disc brake, and riders who ride faster,braking hard from high speed will put some load on them little bearings, as do bumpy roads and pot holes, its something i might use in the future
Posted: Sun Feb 26, 2017 12:45 am
by Donnie
holty wrote:the bottom bearing has much bigger balls so is stronger, plus you can always add lots of balls and no cage, top however is made with very small balls so isnt as strong, probably aimed at scooters with a good front disc brake, and riders who ride faster,braking hard from high speed will put some load on them little bearings, as do bumpy roads and pot holes, its something i might use in the future
really?
Posted: Sun Feb 26, 2017 8:45 am
by fluff34567
On frankland page I only see a bearing kit for the fork links.
Posted: Sun Feb 26, 2017 8:57 am
by fluff34567
Found it...... Image £58 on ebay
