anodizing alloy
Posted: Fri Feb 24, 2017 10:11 pm
by joespeed
anyone do this in yorkshire?
Re: anodizing alloy
Posted: Sat Apr 29, 2017 4:07 pm
by mawso
https://www.google.co.uk/search?q=anodi ... e&ie=UTF-8 nobody on your doorstep by the look of it.
Re: anodizing alloy
Posted: Sun Apr 30, 2017 2:57 pm
by joespeed
thanks mr mawso, i have been in contact with moss metal finishers in halifax who seem to understand what i need!
Re: anodizing alloy
Posted: Mon May 01, 2017 8:07 am
by warts
There is also a non electrical process called Alodining.
"Alodining is the chemical application of a protective chromate conversion coating on aluminum. The term Alodining has become a generic term for passivation conversion coating on aluminum materials, though in the strictest sense the term only refers to use of the specific Alodine product."
If you can still get the chemicals in reasonable quantities.
Easy to do at home, when ever you have the need. Couple of containers for your bits to fit in. Pair of rubber gloves and goggles. Clock. Jug for mix n'measure.
Re: anodizing alloy
Posted: Mon May 01, 2017 8:59 am
by fluff34567
I use alodine all the time, it's available in clear or straw yellow. It isn't very durable, and is meant as a coating before primer.
The raw chemicals are quite volatile and can combust. You can get pre mix application pens.
Depends what you want to treat.
DO NOT try to anodise a standard cylinder head, it reacts badly with the acid.
